    If you have no led indication for the micro switches & having trouble with the estop as well have you checked that there is power to them, if it's a newer computer with a 3,3v supply to the parallel port you may need to supply the bob with a seperate 5v supply
    dudz's Avatar
    Lives in Dunedin, New Zealand. Last Activity: 09-02-2025 Has a total post count of 295. Received thanks 2 times, giving thanks to others 79 times.
    Its an old PC. I have never had to use the LPT1 port before. I will measure the voltage.
    If the machine actually moves this will just be a simple Mach setup problem. The E-stop was actually working and changing pin selection proved So I would guess the rest of pins are fine.? What you should have done is toggle the active Low. Mach was sensing the signal the wrong side so thinks the E-stops activated.
    Not sure what you mean about resource tab showing the same settings has in Mach.? The only number in ports&pins that relates to the LPT is port address and that is only entered in one place on the first screen. From then on the only number in the other screens IE Inputs,Outputs etc that relates to the LPT is port number 1 or 2 depending if you set port 1 or 2 on frst screen with the LPT address.
    With the limit switch( and all other I/O's) you will need to know the pin number from the BOB and enter that number in Port&Pins/Input signals/X++/x--/pin number do the same for each Axis.
    Without the BOB pinout you will be stabbing in the dark.
    After doing this check diagnostics screen and the M1++limit/2/3etc LEDs and if lit without switch tripped the toggle the Active Low again.
    If you still struggle then post the make of the BOB and any pin info you may have I'll take a look for ya.
  1. Wiring home and limit switches
    Last Post: 18-11-2023, 06:14 PM
  2. 24v Limit/Home switches. How to..?
    By Wal in forum General Electronics
    Last Post: 17-11-2013, 05:52 PM
  3. Boxford 240 home switches?
    By X3Chalk in forum Boxford Lathes
    Last Post: 17-04-2012, 07:07 PM
  4. value of home switches
    By engineshed in forum General Electronics
    Last Post: 04-04-2012, 12:01 AM
  5. Limit/home switches - how are you mounting 'em?
    Last Post: 13-11-2011, 01:42 PM
