Neal, I would seriously think about putting up a design for the machine you are building or starting a build log, you could save yourself wasting money, time & effort which if you are on a tight budget is going to be of real value.
I already have a couple of reservations from what you have said, not sure that 3/4 ally angle is wide enough for use with skate bearings ( I assume that's what your using) secondly what gauge is it as 1/16 won't be suitable.
What sort of router do you intend using & how are you going to control the spindle speed which you will need to do for cutting acrylic.
11-11-2012 #2
Hi martin,
I think you're right. Better to give you guys the whole scope of the build instead of little bits and pieces. I had a fixed plan in my head, but everytime I look at somebody's build log, I change little things here and there.
I have 1/8" thickness aluminium angle mate. I bought a router recently for trimming parts to size and making grooves, but I didn't think It would be good for a cnc router. Its a bosch POF 1200AE as in the pic below. I'll probably be going for a dewalt palm router and build a motor control circuit to vary the speed.
Is the angle still going to be too thin at 1/8", because if it is then I'm definitely going for 1" steel pipe instead.
Digital angle gauge
By njhussey in forum Tool & Tooling TechnologyReplies: 4Last Post: 04-12-2012, 08:07 PM -
looking for 6061 T6 Aluminium angle
By Ccrewz in forum Gantry/Router Machines & BuildingReplies: 1Last Post: 09-04-2011, 09:10 PM -
WANTED: looking for 6061 T6 Aluminium angle
By Ccrewz in forum Items WantedReplies: 0Last Post: 31-03-2011, 07:54 AM -
RockCliff redesign in Al Angle
By templecorran in forum Gantry/Router Machines & BuildingReplies: 0Last Post: 27-07-2009, 12:57 PM
