12-11-2012 #6
If the shank on the tool is 1/2", then ER11 is insufficient since, as GTjim said, that size collet will only accept up to 7mm. The minimum size collet series that accepts 1/2" is ER-20 which goes up to 13mm, so unless you can make some sort of adapter which is 7mm on one end and has a 1/2" hole in the other...you're stuck. That may be possible since a drag knife isn't spinning fast, so the rigidity isn't so much of a problem. Possibly the tool itself could be modified on a lathe to give it a 7mm shank?
Looking at the tool in question..
It looks like it could be modified, so long as it's not made from a very hard grade of steel, which seems unlikely.
spindle with compressed air release collet
By GEOFFREY in forum Spindles & Drive MotorsReplies: 4Last Post: 20-02-2014, 01:06 AM -
FOR SALE: For Sale, Chinese 1.5kw spindle (er11 collet) with matching VFD! with 4 & 6mm collet
By jcb121 in forum Items For SaleReplies: 1Last Post: 29-01-2013, 11:05 AM -
CNC 3040 Collet size and other questions?
By Musht in forum Milling Machines, Builds & ConversionsReplies: 11Last Post: 15-02-2012, 02:26 AM -
ER11 Collet size lying?
By Philly in forum Tool & Tooling TechnologyReplies: 6Last Post: 14-04-2011, 12:26 PM -
Question regarding CMD 10 Collet sets
By Englishlever in forum Tool & Tooling TechnologyReplies: 22Last Post: 07-09-2010, 10:10 PM
