13-11-2012 #5
deapth of cut with a 6mm tool would be dependant on your machines rigidity
with a router we tend to feed a shallow cut quicker rather than deap one slower... if that makes sense
if your chips are like dust your tool life may be vastly shortend as it will be doing quite a bit of rubbing and only taking a cut on every other revolution or worse
the ideal is to be taking a consistant healthy chip... if your aluminium is gummy it can be really hard to acheive this and plenty of WD40 and an old tooth brush to clear as much of wast as you cut is as good as it gets
it this stage it may be worth being really experimental with your speeds and feeds and eccept any tool loses as part of the process of finding the sweet spot
being conservative can damage your tool just like being agressive
in my opinion, if you have an idea of a healthy chip it doesnt matter what your cutting, youll have the ability to nudge the feed or spindle speed on the hoof and over time youll start to add your knowlege at the g-code levelLast edited by blackburn mark; 13-11-2012 at 02:01 PM.
Feeds and speeds
By dudz in forum Tool & Tooling TechnologyReplies: 0Last Post: 26-08-2013, 11:42 AM -
Engineering Calculators - speeds, feeds, torque, etc.
By birchy in forum Machine DiscussionReplies: 0Last Post: 16-06-2013, 01:42 PM -
Speeds and feeds deep drilling
By Razorab in forum Sieg Milling MachinesReplies: 13Last Post: 10-02-2013, 09:00 PM -
Speeds and Feeds
By Web Goblin in forum Tool & Tooling TechnologyReplies: 0Last Post: 20-09-2012, 01:38 PM -
Advice needed for Z Design
By Hobgoblin in forum Linear & Rotary MotionReplies: 8Last Post: 10-09-2012, 09:18 PM
