    dudz's Avatar
    Lives in Dunedin, New Zealand. Last Activity: 09-02-2025 Has a total post count of 295. Received thanks 2 times, giving thanks to others 79 times.
    I am learning to use Mach3 for my CNC/router machine. I have the demo version.
    I load the wizard inside Mach and pick one of the tabs. Why am I getting the X,Y and Z axis under the visual table in the display window ? as the file executes, in the display the tool starts at the bottom and works its way up towards the table. Obviously I have something set wrong, but I have changed almost everything I can think of but no luck.
    assuming i know what your saying...
    off the top of my head i can only think you have your Z going + on the plunge instead of -
    go to motor setup and select or un select active low for your Z axis (i think)
    dudz's Avatar
    I think i have sust it. In the "Homing/limits" tab, I just put a minus in front of the Z axis "Soft min" table height. That seems to of fixed it
    Not up & running myself yet but have you watched any of the video tutorials for mach3? You can find them here
    ArtSoft USA - Videos
    May be worth a try if you haven't already checked.
    dudz's Avatar
    Quote Originally Posted by martin54 View Post
    Yes I have, but I have one PC. No internet in my workshop....so when I finish watching a vid, I have to unplug everything...take it into the workshop...reconnect everything to my CNC. A right pain in the arse !
    Sounds like you need to look on fleabay for a cheap desktop pc for the workshop, you can pick them up for less than 50 quid
    Neil...
    Build log...here
    Or if you don't fancy a second hand computer you could either buy a 200 mtr long cable & leave the computer where it is or download the tutorials & watch them from the comfort of your workshop
    Lives in Marple Stockport, United Kingdom. Last Activity: 13 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    200mtr I thought that the max was about 100mtr without a switch because of timeing issues
  1. RFQ: Small sized Parts need making, small batches
    By Ptee in forum Projects, Jobs & Requests
    Last Post: 17-01-2014, 06:07 PM
  2. Mach3 & V-Carve Problem
    By Ricardoco in forum Computer Software
    Last Post: 31-05-2013, 12:53 PM
  3. Problem with X
    By gorbo in forum General Discussion
    Last Post: 24-02-2011, 05:33 AM
  4. Z Problem
    By airwolf in forum Machine Discussion
    Last Post: 10-11-2009, 08:08 AM
  5. Machine problem with softlimits mach3 & Estop
    By Steve-m in forum Artsoft Mach (3 & 4)
    Last Post: 12-01-2009, 05:38 PM
