Ive looked at Building a power supply but "NO", I have no time, and No inclenation to build one so, Im looking to buy a power supply to run 4 x nema23 4nm motors on the front of 4 x MA860H drivers.
The Drivers spec:-
2MA860H Features:
- High performance, cost-effective
- Supply voltage up to DC(24-110V) AC(50-80V)
- Output current up to 7.2A
- Self-adjustment technology
- Pure-sinusoidal current control technology
- Pulse input frequency up to 200 KHz
- TTL compatible and optically isolated input
- Automatic idle-current reduction
- 15 selectable resolutions in decimal and binary, up to 12,800 steps/rev
- Suitable for 2-phase motors
- Support PUL/DIR and CW/CCW modes
- Short-voltage, over-voltage, over-current protections
Any sources or suggestions would be magic.
RickAlways bear in mind that your own resolution to succeed is more important than any other - Abe Lincoln
13-11-2012 #2
since the drivers support ac why not just wire them up to a transformer, its not exactly building a power supply
Toroidal Transformer 625va 0 55v 0 55v
this 625VA toroidal would provide 55VAC @11.4A
they also have 800VA & 1000VA ones available (1000VA giving 18.2A)
btw im not exactly an electronics guru so hopefully one of the more knowledgeable members can chime in
13-11-2012 #3
Hi, well jonathan did hint at a similar idea and i did look for the diagram that i had heard was here but to no avail, but an unregulated power supply just flies in the face of what my brain tells me, S0 i just thought there must be an off the shelf solution, but from the lack of responses it appears Jazz is not the only one being silent here tonight
Mind you not sure about the "Normally Despatched" "1-2 Months bit on the link you sent me lol
RickLast edited by Ricardoco; 13-11-2012 at 09:46 PM.
13-11-2012 #4
Rick, I'm not an expert but this may help, Taken from the leadshine AM882 driver manual.
Both regulated and unregulated power supplies can be used to supply the drive. However,
unregulated power supplies are preferred due to their ability to withstand current surge. If regulated
power supplies (such as most switching supplies.) are indeed used, it is important to have large
current output rating to avoid problems like current clamp, for example using 4A supply for 3A
motor-drive operation. On the other hand, if unregulated supply is used, one may use a power supply
of lower current rating than that of motor (typically 50%~70% of motor current). The reason is that
the drive draws current from the power supply capacitor of the unregulated supply only during the
ON duration of the PWM cycle, but not during the OFF duration. Therefore, the average current
withdrawn from power supply is considerably less than motor current. For example, two 3A motors
can be well supplied by one power supply of 4A rating
13-11-2012 #5Always bear in mind that your own resolution to succeed is more important than any other - Abe Lincoln
13-11-2012 #6
I've got a spare one and the rest of the bits...will contact you about it.
This is the diagram I sent to Ricardoco in case anyone else wants it:
Untitled Page
The Following 2 Users Say Thank You to Jonathan For This Useful Post:
14-11-2012 #7
14-11-2012 #8
13-11-2012 #9
Rick Jazz emailed me all the stuff for the transformer & the control box. It's on the other computer but will sort it out & send it to you tomorrow.
14-11-2012 #10
PCPPS V3 Power Supply?
By birchy in forum General ElectronicsReplies: 4Last Post: 10-12-2012, 04:21 PM -
Minimal-cost Power Supply Strategy - Repurpose Laptop Power Supplies
By LoveLearn in forum General ElectronicsReplies: 0Last Post: 25-01-2012, 09:29 PM -
WANTED: Power Supply wanted
By fasteddy in forum Items WantedReplies: 6Last Post: 31-07-2011, 11:00 PM -
FOR SALE: 50V 20A Power supply
By Jimmybristol in forum Items For SaleReplies: 8Last Post: 30-05-2011, 11:01 PM -
power supply
By hitmythumb in forum General ElectronicsReplies: 6Last Post: 21-06-2009, 10:27 AM
