Rick, I'm not an expert but this may help, Taken from the leadshine AM882 driver manual.
Both regulated and unregulated power supplies can be used to supply the drive. However,
unregulated power supplies are preferred due to their ability to withstand current surge. If regulated
power supplies (such as most switching supplies.) are indeed used, it is important to have large
current output rating to avoid problems like current clamp, for example using 4A supply for 3A
motor-drive operation. On the other hand, if unregulated supply is used, one may use a power supply
of lower current rating than that of motor (typically 50%~70% of motor current). The reason is that
the drive draws current from the power supply capacitor of the unregulated supply only during the
ON duration of the PWM cycle, but not during the OFF duration. Therefore, the average current
withdrawn from power supply is considerably less than motor current. For example, two 3A motors
can be well supplied by one power supply of 4A rating
13-11-2012 #2Always bear in mind that your own resolution to succeed is more important than any other - Abe Lincoln
13-11-2012 #3
I've got a spare one and the rest of the bits...will contact you about it.
This is the diagram I sent to Ricardoco in case anyone else wants it:
Untitled Page
The Following 2 Users Say Thank You to Jonathan For This Useful Post:
14-11-2012 #4
14-11-2012 #5
PCPPS V3 Power Supply?
By birchy in forum General ElectronicsReplies: 4Last Post: 10-12-2012, 04:21 PM -
Minimal-cost Power Supply Strategy - Repurpose Laptop Power Supplies
By LoveLearn in forum General ElectronicsReplies: 0Last Post: 25-01-2012, 09:29 PM -
WANTED: Power Supply wanted
By fasteddy in forum Items WantedReplies: 6Last Post: 31-07-2011, 11:00 PM -
FOR SALE: 50V 20A Power supply
By Jimmybristol in forum Items For SaleReplies: 8Last Post: 30-05-2011, 11:01 PM -
power supply
By hitmythumb in forum General ElectronicsReplies: 6Last Post: 21-06-2009, 10:27 AM
