OK i did ask about off the shelf din solutions giving me the ability to simply add extra units as and when i needed them and it seemed that opinion was against that, so as this isnt going to just look like a box of spagetti like a lot of projects i see turn out, i had to factor in not only what i want now but also guess what i may need in the future, the last thing i want is to keep stripping the damn thing down to do mods. I want to wire the Box, take into consideration what i need at the time of building and build it, and if that includes a 6" fan or two for cooling then so be it, shut the door on the cabinet and dont open it till the warning light and buzzer comes on, Yes there may be a heat dissaption requirement by the multiple 2n3055's but it wont be the first successfull supply ive build by any means, i think i build my first one when i was 12 and although that is long since been stripped for bits my current dual 0-30vdc supply was built by me 25yrs since, and im still very happy with it, although im always happy to try new ideas.
So You know what i have get your thinking head on and show me a better circuit solution. That would be magic
RickAlways bear in mind that your own resolution to succeed is more important than any other - Abe Lincoln
22-11-2012 #2
What wrong using directly an AC Source? for example use directly an transformer 220AC to 110AC?
Is better to use DC Instead AC?
Yes, since at the time there was no mention of powering other things. Still, I wouldn't use them for powering the other things or stepper motors since they're so much more expensive.
My point is that may not be enough - if the transistors aren't rated for the power dissipation required it doesn't matter how big the fans are, it's not going to work (unless you split the power between multiple transistors).
No, I don't know since you've not said exactly what current each of the other devices require and without that there's no point in further speculation.
This thread started by discussing which PSU is most suitable for powering stepper motor drivers, which in general run from a DC source so you have to rectify the transformer output to obtain that.
PCPPS V3 Power Supply?
By birchy in forum General ElectronicsReplies: 4Last Post: 10-12-2012, 04:21 PM -
Minimal-cost Power Supply Strategy - Repurpose Laptop Power Supplies
By LoveLearn in forum General ElectronicsReplies: 0Last Post: 25-01-2012, 09:29 PM -
WANTED: Power Supply wanted
By fasteddy in forum Items WantedReplies: 6Last Post: 31-07-2011, 11:00 PM -
FOR SALE: 50V 20A Power supply
By Jimmybristol in forum Items For SaleReplies: 8Last Post: 30-05-2011, 11:01 PM -
power supply
By hitmythumb in forum General ElectronicsReplies: 6Last Post: 21-06-2009, 10:27 AM
