Hi there,
Sounds like you are in the same position as most of us were/are before we started on this forum. If you read the build threads you'll see the sort of equipment people have used. Mostly along the way things have changed from their initial brief.
Before people will comment on the equipment you'd need you will need to specify the size of machine you want and what you want to cut. You'll also get better responses if you show a design and list the equipment as people will chip in with their advice (usually based on experience)
plasma advise sought, want to make a a3-a2 sized machine
By nobby in forum Plasma Table MachinesReplies: 1Last Post: 16-07-2014, 02:53 PM -
Ancient CNC machine- advice needed!
By tom_65a in forum Machine DiscussionReplies: 6Last Post: 11-05-2014, 11:17 AM -
Deskproto CAM machine relief without sidewalls to try and make a raised relief
By chris in forum CAD & CAM SoftwareReplies: 5Last Post: 27-01-2014, 09:48 PM -
Make your own Super- PID ... not that hard to make ! .... says electronics genius!
By Buba b in forum General ElectronicsReplies: 4Last Post: 26-04-2013, 08:37 AM -
RFQ: Help needed to build my first machine NE Norfolk
By Dorg in forum Projects, Jobs & RequestsReplies: 3Last Post: 31-10-2012, 09:30 AM
