Thread: My build log
15-11-2012 #6
I know SBR25 has one more row of balls compared to SBR20. Not sure about 16mm. Either way you would be much better off getting 20mm (or better) 25mm rails. SBR25 for the 1500mm rails and SBR20 for the rest would be good. It seems you're using 4 rails on the X-axis, which has clear advantages but will make it difficult to align all the rails such that they are parallel.
Yep...
Yep... on X and Y you should use RM1610 since this halves the rpm the ballscrew must do to get a given feedrate, so if the feedrate is limited by the critical speed of the screw (which it certainly will be over 1500mm) then you get the higher pitch screw to compensate. Read any of the build logs on this forum and you'll probably find an explanation of this.
200mm is quite small for the Z-axis, but in a way that's good since if you can cope with having so little travel (50-80mm ish) it makes it easier to design a strong machine.
Waiting until the end is a good idea since it means you don't risk wasting money if your objectives change, however I'll be surprised if you can find a plug and play system that's worth buying. Most of them seem to be very mismatched, or highly overpriced.
By Karl in forum DIY Router Build LogsReplies: 12Last Post: 08-02-2017, 08:03 PM
