Thread: My build log
First off are the concrete blocks sitting on the ground or do you have concrete under them? Also what is the base sitting on near the wall is it slabs? The centres of the joists look quite far apart but that might be the photo. What are the centres? Also you will need to put some DPM between the base frame and whatever your are sitting it onto so that it doesnt suck up moisture.
By Karl in forum DIY Router Build LogsReplies: 12Last Post: 08-02-2017, 08:03 PM
