16-11-2012 #4
With only £1000 it will be tight - you certainly will have to make it yourself to achieve that.
The electrical parts, i.e. 4*3Nm stepper motors, DQ860MA drivers, PSU, breakout-board will be about £300
2.2kW spindle + VFD, which is the only one worth getting for this size machine since you want it to last and cuts lots of different things, about £240
Water pump for spindle, £15
Steel for frame, about £50
You'll need something like this for the ballscrews and rails:
RM1610-1500mm, *2
RM1610-1200mm, *2
RM1605-250mm, *1
Bearing blocks for ballscrews, *4
SBR25-1500mm rails
SBR20-1200mm rails
SBR20-300mm rails
That's about £520 (bit of a guess but should be within 10%).
Pulleys and belts, maybe £35
Total: 300+240+15+50+520+35=£1160
So actually it looks like £1000 isn't realistic for this size machine. There will be other small parts I've not included in that list which all add up, like fasteners, material for bed. Plus I've not included the metal to make the Z-axis and maybe Y, so easily another £100 there - more if you can't cut it yourself. So a realistic budget for this size machine, capable of cutting the materials you suggest, is nearer £1500.
Just to be clear, the above is not intended to be a shopping list - get the design done first before buying anything otherwise you'll have no chance of making it cheaply.
So basically everything!
Help please Steps and control?
By totts in forum Motor Drivers & ControllersReplies: 9Last Post: 31-03-2012, 07:44 PM -
Z-axis huge slack / beginning a conversion
By diy-john in forum Gantry/Router Machines & BuildingReplies: 11Last Post: 04-03-2012, 10:26 PM -
NEW MEMBER: Beginning machine shop needs help with CNC Step High Z S400 Problems
By NorthernLightsMachines in forum New Member IntroductionsReplies: 2Last Post: 24-07-2011, 09:41 AM -
z axis loosing steps
By ptjw7uk in forum Machine DiscussionReplies: 23Last Post: 10-05-2010, 07:38 PM
