Thats a big motor, will get some nice grunt from that but will lack rpm, would you be gearing it up a bit?
Being able to use a shiney new cnc lathe that i can get my hands on, im going to be trying to design and make a bt30 atc spindle. May be a bit optimistic. But time will tell.
14-04-2013 #2
very nice indeed. what size bearings did you use?
How have you pre-loaded the bearings? For machining metal you would ideally have a decent amount of fixed pre-load but for high speed they are normally spring preloaded. Having said that most of the spindles on ebay etc are spring preloaded and I believe people use them milling metal ok, as with all design its a case of compromise you have to decide how fast you want to cut metal as in reality you will just have to take slower and shallower cuts. This is the same problem I came up against when I was looking at a spindle capable of milling meatal and routing wood. I have put mine on hold as I have decided to go down the adjustable hydraulic pre-load and air/oil lubrication route, which means a lot more work and probably a few trial runs.
With all steel construction how are you going to deal with the heat dissipation at high speed? would a finned Ali housing for the motor be better? or are you using the top as the mount to the machine?
Look forward seeing how you get on with this.
14-04-2013 #3
@ Ross, im using 2 12mm ID AC bearings up front, Nachi #7201B i think they were. Rear is a 12mm radial bearing.
well, on the preload issue, i've got the bearing pocket slightly undersized in depth & im using a shim between the bearings. preload is by tightening down on the bearing retainer cover. its not very high tech, but i figure im going to run this as is & see how long it lasts. not very scientific i know.
as to the Heat dissapation, ive got one big vent hole to draw in air on the front of the square block with 4 smaller vent holes on the top of the block, where the motor mounts. the square block will bolt into the Z-axis moving plate with 4 bolts.
one thing im worried about is the weight. its at 5kg already, i designed my z axis on 4 THK RSR 9WN's...
14-04-2013 #4
14-04-2013 #5
eBay: 300W 12V-48V DC High speed air cooled spindle motor for engraving milling
By Swarfing in forum Items On eBay UKReplies: 0Last Post: 16-06-2013, 01:33 PM -
Can anyone recommend a spindle for milling PCB and cast acrylic?
By HankMcSpank in forum Spindles & Drive MotorsReplies: 10Last Post: 11-10-2011, 08:54 PM -
WANTED: Wanted: Small Metal Work Milling Machine
By 07trb in forum Items WantedReplies: 0Last Post: 04-03-2011, 06:58 PM -
A little help on designing in Solidworks
By D-man in forum Computer SoftwareReplies: 3Last Post: 04-11-2010, 10:49 PM -
Looking for some help designing my gantry please
By psiron in forum Gantry/Router Machines & BuildingReplies: 13Last Post: 05-07-2010, 09:52 PM
