Thread: Help! Boxford 125 TCL CNC lathe
Hi 'sir' (pun on teacher)
Ok, I am new to this, but have read a lot in the past few weeks and I do not doubt I will be corrected if I am wrong. But I believe the most simple thing you can do is 'convert' it. Think im right in thinking the native Boxford equiptment used BBC micro's. which im sure you will agree are long since any use to man or beast.
Most of the home made CNC routers / millers etc you see on here and on youtube, are done with components that make up the automation side of the cnc, essentially you buy some stepper motors mount them to the machine. you then buy a controller for each stepper, and a suitable power supply. you then connect these 'controllers' to a break-out board and the break-out board is compatable with most of the reasonably cheap CAD/CAM software available in the modern internet age. Mach3 is a common tool used to control the machine and will take DXF files staight from autocad etc.
perhaps something like this
http://www.zappautomation.co.uk/en/s...hree-axis.html
a mach3 licence.
and some tinkering to connect the steppers to the axis drivescrews and jobs a good-un. Have a look on you-tube there are loads of videos of boxford conversions.
so in answer to your question sub £500 (or whatever that is in euros). Good project for the kids!!
here some related links from a quick google
boxford 125 tlc | Model Engineer
http://www.mycncuk.com/forums/machin...-software.html
remember, dont take anything ive said as gospel. do some research and keep us posted with your plans.
Matt
The Following User Says Thank You to kingcreaky For This Useful Post:
21-09-2020 #2
If it is of any use to you, I have a BBC computer that you could have. However, I suggest throwing the electronics in the bin and rebuilding with a Raspberry Pi, Beagle Bone, or arduino as the controller. There are hundreds if not thousands of ways to do it, and I am sure that someone has already done something similar. I recently bought a co-ordinate measuring system which I intend to convert for 3D printing, with a working volume of about 1.5m^3.
FOR SALE: Boxford 240 TCL Lathe
By bman in forum Items For SaleReplies: 15Last Post: 20-11-2018, 03:33 PM -
Boxford 160 tcl bench top cnc lathe
By sbdtasos in forum Boxford LathesReplies: 0Last Post: 18-04-2015, 03:08 PM -
FOR SALE: Boxford 160 TCL Bench Top Lathe
By Bartell in forum Items For SaleReplies: 6Last Post: 12-11-2014, 09:52 AM -
How OLD is my boxford lathe?
By Raymond in forum Boxford LathesReplies: 4Last Post: 11-08-2014, 02:17 PM -
boxford csb lathe
By onecut in forum Boxford LathesReplies: 0Last Post: 14-07-2013, 11:52 AM
