    This guy might have manuals etc as hes selling one on ebay Link you could try to contact him and ask if he has the manuals and if he could photo copy them for you?
    Boxford 125 TCL Training Computer lathe
    The 125 is a bench top slant bed CNC training lathe. It is the ideal machine for introducing CNC to students or for use in workshops
    Compact and portable it cuts steel
    This Machine can be operated in manual mode without the computer.
    Lathe Specifications and capabilties:
    Swing over bed (single point tooling) dia 160mm x 125mm
    Swing over X Axis slide dia 70mm x 125mm
    Swing over gang tooling sub plate dia 50mm x 125mm
    Programmable spindle speeds 40 to 3000rpm
    Main drive moter 0.44kW
    Programmable feed rates 1 to 300mm/min (04 to 12''/min.)
    Rapid traverse rate (100%) 350mm
    Programmable thread pitches (inch and metric)
    Tailstock - swinging body arrangement to clear multiple tooling set ups, in simulated chucking cycles
    Axis drive system - pre-loaded ball screws and stepping motors in both X and Z Axis.
    Lubrication - permanent grease on spindle and ball screws - oil lubricators on slides
    Ralph Waldo Emerson
  2. The Following User Says Thank You to Fivetide For This Useful Post:
  1. FOR SALE: Boxford 240 TCL Lathe
    By bman in forum Items For Sale
    Last Post: 20-11-2018, 03:33 PM
  2. Boxford 160 tcl bench top cnc lathe
    By sbdtasos in forum Boxford Lathes
    Last Post: 18-04-2015, 03:08 PM
  3. FOR SALE: Boxford 160 TCL Bench Top Lathe
    Last Post: 12-11-2014, 09:52 AM
  4. How OLD is my boxford lathe?
    By Raymond in forum Boxford Lathes
    Last Post: 11-08-2014, 02:17 PM
  5. boxford csb lathe
    By onecut in forum Boxford Lathes
    Last Post: 14-07-2013, 11:52 AM
