One or two flute cutters are readily available, so if you don't mind reducing the feedrate to half or a third of what you would use with 3fl, you could use less flutes:
5pcs 1.5mm Single Flute Carbide Spiral End Mills Router Bit 6mm CEL | eBay
22-11-2012 #2
Unfortunately this is a propitiatory machine i.e. chuck fitting , cutter speed, so I can't change anything.
The only thing I can do is look for an alternative supplier, someone has to make these cutters, they can't be that unique.
If they were more sensibly priced I wouldn't be spending my time trying to find the "holy grail"
If anyone is interested in key cutting to code this video link is the same as my machine
Bianchi Laser 994 Edge - Cut by Decode & Code - YouTube
Thanks for your assistance
Can you recommend a UK Supplier for cnc router bits
By GeoDurie in forum Tool & Tooling TechnologyReplies: 0Last Post: 06-06-2014, 10:40 AM -
The tips of my 20 mill cutter get loose ...
By hoezap in forum Tool & Tooling TechnologyReplies: 0Last Post: 06-07-2013, 11:55 AM -
Which kit would you recommend?
By ian823478 in forum Motor Drivers & ControllersReplies: 2Last Post: 08-04-2012, 11:05 PM -
1.5mm ball end mill supplier in the uk
By luke11cnc in forum Marketplace DiscussionReplies: 9Last Post: 21-01-2012, 08:25 PM -
Please Recommend me a CNC mill for....
By Gasgasbones in forum General DiscussionReplies: 4Last Post: 29-11-2010, 07:17 PM
