Quote Originally Posted by martin54 View Post
Try giving Roland a call, I am guessing that if they do still have a power supply it will be expensive. Never dealt with them myself but have read on other forums that their technical department can be very helpful.
I actually had to call them about a missing PSU for a keyboard once. They were very helpful, but like you say, expensive. For now I have replaced the power socket with screw terminals and semi-permanently attached my power supply.
Last night I bought a DB9->DB25 serial converter and a LPT cable from Maplin, unfortunately neither worked, the LPT probably because I wasn't configuring it correctly on the PC, and the serial because they use a non-standard wiring. So I made a serial cable with things I had around already and hey presto! So now I have a PC interface working for it, and can move it around. I am planning to buy a dremel 4000 and the dremel drill press/vice thing, and make a part to attach to the carriage that used to hold the electromagnet that put the pen down. Will update as I go - should I make a build thread somewhere else or just use this one?
