Thread: correcting mill spindle runout
18-01-2009 #1
The run-out on my mill is measuring about 0.1 mm, I've checked it with a few other tools I think I've narrowed it down to the taper inside the spindle.
I've cleaned out the spindle bearings and this improved things a tiny amount, but this is really stopping me from squaring the machine / head properly; this is also evident in the poor finish Im getting.
I've also found that the taper is only in contact with the lower 50% of the tool, is this going to be a contributing factor?
As I only have the Mill, my options are a bit limited, but Im currently thinking of getting a MT3 reamer to centre things up a bit, are there any other idas/ways to approach this problem?
Thanks in advance,
James
RFQ: Spindle Mount (Ali mill job) - one off
By Doddy in forum Projects, Jobs & RequestsReplies: 3Last Post: 05-02-2014, 06:42 PM -
ER Collet runout investigation Cheap Vs Brand
By booski in forum Tool & Tooling TechnologyReplies: 1Last Post: 19-08-2013, 12:01 PM -
zero or minimal runout - shaft part
By dsc in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 06-12-2012, 03:09 PM -
X2 Mill R8 Spindle
By Scott in forum Sieg Milling MachinesReplies: 4Last Post: 29-12-2011, 04:40 PM -
Measuring Spindle Runout
By Lee Roberts in forum Spindles & Drive MotorsReplies: 0Last Post: 18-10-2008, 11:47 PM
