Thread: correcting mill spindle runout
Personally if its only 2- 3 months old and you bought it new I'd get the vendor to deal with it - it shouldn't have a problem of that nature.
It could be a bit of dirt in the taper tho. What you could do is get some engineers blue and put a very fine coating on a taper then draw it into the spindle. Carefully drop it out again and see if there's any obvious marking where the blue has been rubbed off... 0.1mm is 4thou and you should be able to do better than 1/2 of that at least.
I'm assuming here that the tooling is pulled in by a drawbar? If so, how tight do you go?
RFQ: Spindle Mount (Ali mill job) - one off
By Doddy in forum Projects, Jobs & RequestsReplies: 3Last Post: 05-02-2014, 06:42 PM -
ER Collet runout investigation Cheap Vs Brand
By booski in forum Tool & Tooling TechnologyReplies: 1Last Post: 19-08-2013, 12:01 PM -
zero or minimal runout - shaft part
By dsc in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 06-12-2012, 03:09 PM -
X2 Mill R8 Spindle
By Scott in forum Sieg Milling MachinesReplies: 4Last Post: 29-12-2011, 04:40 PM -
Measuring Spindle Runout
By Lee Roberts in forum Spindles & Drive MotorsReplies: 0Last Post: 18-10-2008, 11:47 PM
