27-11-2012 #7
I don't think there's any need to use stainless steel - normal mild steel would be fine. You could make the inserts thread into the guide block. If you hold them with a grubscrew, machine a small flat on the insert for the grubscrew to push against otherwise the burr will stop the insert coming out easily. Could make the inserts 'top hat' shaped so that they're easier to pull out...
Drill / Tap Guide Jig - Finished!
By Wal in forum Metalwork Project ShowcaseReplies: 10Last Post: 04-12-2014, 09:59 PM -
10 / 15mm thick 6061 aluminium alloy sheet ?
By rnr107 in forum Marketplace DiscussionReplies: 10Last Post: 14-01-2014, 12:15 AM -
RFQ: Rounded slot milled through 15mm Aluminium plate
By TonyD in forum Projects, Jobs & RequestsReplies: 2Last Post: 15-02-2013, 11:20 AM -
what is aluminium plate
By martin54 in forum General DiscussionReplies: 10Last Post: 11-10-2012, 01:44 AM
