Thread: Milling Steel?
If the routers frame and Z axis is strong and you keep the extension to a minimum by lifting the work to the spindle then it will do it no problem with the correct end mills. Yes Slower when it comes to removing large amounts of material but not when it comes to finish on small things like moulds.
The moving bed or gantry doesn't really come into it. Just more common for mills and easier to build strong machines with limited travel if fixed gantry.
The higher speed of router spindles will actually give you a better finish than slow milling spindles when using small end mills needed for detailed moulds like you suggest has they often don't spin much above 3000rpm and 10,000 rpm + is not uncommon.
That said if I was mainly or even just more than occasionally cutting steel then I'd buy a Mill with the fastest spindle I could afford or buy speed increaser.!! Steel really does stress a router out.!
Steel vs Aluminium
By gavztheouch in forum Metalwork DiscussionReplies: 4Last Post: 26-05-2014, 10:11 PM -
Milling mild steel
By dudz in forum Machine DiscussionReplies: 33Last Post: 16-02-2014, 02:31 PM -
Need help, buy or build to cut steel, stainless steel, titanium etc
By fatguyslim in forum Machine DiscussionReplies: 41Last Post: 08-02-2014, 11:37 PM -
Milling vice, general milling vice or tool vice?
By Web Goblin in forum Tool & Tooling TechnologyReplies: 4Last Post: 15-12-2012, 11:15 PM -
WANTED: Steel Off-cut!
By Tenson in forum Items WantedReplies: 1Last Post: 27-04-2012, 05:59 PM
