    If you're planning on getting the rails from that seller then you can get 25mm for the same price here, or maybe less here if you send the seller a message. I'd go for 25mm since they have one more row of balls than the 20mm rails, so are correspondingly stronger. Having said that either will be a huge improvement on what you have now.
    dudz's Avatar
    Lives in Dunedin, New Zealand. Last Activity: 09-02-2025 Has a total post count of 295. Received thanks 2 times, giving thanks to others 79 times.
    hmmmm..... I just payed 37 euros taxes for an item from the US which cost 85 dollars.
    Swedish Storbro Luna - 3 axis CNC mIll - 250 - 2500rpm / 1.1 tonne
    dudz's Avatar
    Ah ha.. probably these : x20 T-Nuts Slot 10 M6 1001 | eBay
  1. BUILD LOG: 3 Axis Router
  2. BUILD LOG: 3 Axis CNC router
    By JoeHarris in forum DIY Router Build Logs
    Last Post: 21-06-2020, 10:41 PM
  3. 3-Axis CNC Router - For Helices.
  4. BUILD LOG: Wobbly: my first 3-axis router
