    dudz's Avatar
    Lives in Dunedin, New Zealand. Last Activity: 4 Weeks Ago Has a total post count of 295. Received thanks 2 times, giving thanks to others 79 times.
    Ok.... I received my Aluminium via UPS. 470mm X 300mm X25mm
    I clamped it down to the original bent Vacuum bed (which temporarily straightened it)... planned the new supported rail bearing block mounting holes in CamBam and successfully drilled and counter-bored the holes. First thing I have ever done with this machine since changing the Z axis plate and adding the 2.2kw Chinese spindle. What an improvement so far !
    Still a way to go to make it more sturdy, but I am already planning the next improvements to come.
    Now... in respect of holes for clamps on the cutting bed.....For now I am going to drill and tap some holes for clamps. (maybe cutting slots later if needed). What size metric holes should I use for the clamps ? M4/M6 ?? and what depth ?
    Swedish Storbro Luna - 3 axis CNC mIll - 250 - 2500rpm / 1.1 tonne with Heidenhein TNC155A controller.
  1. BUILD LOG: 3 Axis Router
  2. BUILD LOG: 3 Axis CNC router
    By JoeHarris in forum DIY Router Build Logs
    Last Post: 21-06-2020, 10:41 PM
  3. 3-Axis CNC Router - For Helices.
  4. BUILD LOG: Wobbly: my first 3-axis router
