Thread: 7' X 4' Combi
02-01-2013 #11
All it needs is at one side of each set of bearings to have the side of the pocket line up with the edge of the bearing, so the bearing or rail Butt's upto it.
So IE: On the Z axis have say the left bearings align with the pocket edges, same with rails on Left side. With the Y axis have the upper Bearings align with upper pocket edges, the rails you'll have to deal with on the Gantry but same applies a straight and true Register helps.
The rest of the pockets can be any size so long has the bearings and rails fit inside and infact a bit of wiggle room helps.
Ye thats what I feared.!! Don't do that it's too inflexible.! "Adjustment" "Adjustment" "Adjustment" is the secret to the whole machine and Esp the setting up of the Z axis and ball-screw alignments.
Ask anyone who's done it the difference between working and locking up is silly small and if you haven't got easy or multiple ways to adjust then life will be frustrating.!!Last edited by JAZZCNC; 02-01-2013 at 06:38 PM.
