Thread: 7' X 4' Combi
Ok more snippets, Sorted the tuning and did a video, the initial G28 move is at 8m Min and the rest is at 7m Min. and this is a boring video but here it is anyhow.
I actually played with the max feed and had to turn up the kernel speed but got to 13m Min with no problems but I was a bit worried about the amount of torque drop of so backed it off to 8m for nice rapids. Does any know if there is a graph that shows the torque drop off related to rpm of these 4nm nema 24 motors, i cannot find it anywhere..
RickLast edited by Ricardoco; 02-04-2013 at 11:56 AM.
The Following User Says Thank You to Ricardoco For This Useful Post:
02-04-2013 #2
Great stuff Rick, now lets see some swarf/sawdust. G.
02-04-2013 #3
LOL the bed will be cast next week and then there is the Y to mount and that will be after the Z backplate arrives.. So its all in flux, Im waiting for the Drag chain, grommets, inline plugs, and the proximity sensors to arrive, then i can chase all the wiring through the frame and through the drag chain (damn that stuff is expensive) there is a bit of welding under the frame to be completed for the shelves for the vacuum pumps, and the dust sucker, the coolant reservour, compressor,VFD, and plasma . But im going as quick as i can cos i want it going..
RickLast edited by Ricardoco; 02-04-2013 at 06:12 PM.
03-04-2013 #4
Sorry Rick, I thought you were a bit further down the line than that. I had not realized you still had so much to do, but at the speed your'e going at it won't be long now. G.
16-04-2013 #5
Well there is a lesson learned!!.
Today I fitted the drag chain, and spent two hours drilling, and routing the cables through the frame back to the control box, Oh how neat it was, i fitted three bright new NPN-NO-6-36v proximity sensors to the X- Axis....LOL oh what fun that was.
Evertime i powered up the driver a sensor triggered, I didnt know what was going on.
I had used some 5 core cable for the steppers leaving 1 spare wire in each cable for the sensor, I had already run some wire up to the gantry for the sensor supply..
So now that i know i will have to use Screened cables on the machine so i dont get all these stray signals.
Can anyone suggest a four core screened cable that wont rip my arm off please, as i will wire the whole machine with what ever i get.
The drivers are 2MA860H Peak 7.2A AC50V-80V DC36V-110V running at 72VAC driving 4NM NEMA 24 Motors
RickAlways bear in mind that your own resolution to succeed is more important than any other - Abe Lincoln
16-04-2013 #6
Here you go. CY Cable 4 Core
Don't run power cables along side signal cables.! Even shielded cables else your asking for trouble.
16-04-2013 #7
16-04-2013 #8
Dean,
Is that 4 core 4 numbered cores plus earth or 3cores and earth ?John S -
