Thread: Lathe / Milling for dummies
Hi Matt
Don't want to teach Granny how to suck eggs, but you seem to be measuring a Jacobs taper which is mounted in the milling head taper and thinking to mount a collet chuck on it.
I'm wondering if you are confused about what you are looking at. The Jacobs taper adaptor is a round lump of iron with a taper on either end.
It's the other taper you want to knock out, the one that goes up into the spindle by hammering from above. The Jacobs taper is irrelevant.
Drill chucks don't make good milling heads because they depend somewhat on the downward drilling force to keep them in place. Once you lose that downward force they can vibrate off.
best
Robin
BUILD LOG: CNC for dummies...Some electrics advice please...pretty please...
By andy586 in forum DIY Router Build LogsReplies: 6Last Post: 01-06-2014, 11:13 AM -
RFQ: Dublin, IRL Manual milling & lathe work required
By 250rri in forum Projects, Jobs & RequestsReplies: 0Last Post: 30-01-2014, 01:07 PM -
RFQ: Looking for Aluminium CNC Milling Service + Lathe Work (2 Separate Jobs)
By biketrialsdave in forum Projects, Jobs & RequestsReplies: 2Last Post: 19-02-2013, 04:06 PM -
4th Axis running as CNC lathe using milling machine
By Jonathan in forum Milling Machines, Builds & ConversionsReplies: 6Last Post: 21-08-2011, 10:34 AM -
RFQ: Cnc for dummies
By MIAPISH in forum Projects, Jobs & RequestsReplies: 11Last Post: 31-03-2010, 07:33 PM
