Hi
If the unit is secondhand I would disconnect the motor from the output terminals,the relay you can hear might be an overload circuit which may prevent the unit from powering up.
Do you have a test meter?
If yes, just check you do have 230v on the input after you have disconnected the motor.
One thing not to do is to connect or disconnect the motor with the power on to the inverter.
Andy
The Following User Says Thank You to audioandy For This Useful Post:
04-12-2012 #2
yes ive done all of the above, powered it up without the motor connected every combination tried.
im sure the relay im hearing is going into power saving mode maby, seems to come at the same interval, the unit is definatly powering on as it warms up slightly after a while.
How to connect 2.2KW Inverter VFD?
By Tenson in forum Spindles & Drive MotorsReplies: 20Last Post: 13-07-2020, 01:47 PM -
Please help me... It wont work.
By kingcreaky in forum Artsoft Mach (3 & 4)Replies: 12Last Post: 22-01-2014, 10:42 PM -
WANTED: Electrical Box for inverter
By badgerman in forum Items WantedReplies: 1Last Post: 28-09-2013, 11:08 PM -
Teco inverter
By Ronaldo9 in forum Spindles & Drive MotorsReplies: 9Last Post: 20-01-2013, 01:42 PM -
Wiring a Teco inverter
By Robin Hewitt in forum General ElectronicsReplies: 9Last Post: 04-04-2009, 09:12 PM
