Thread: bitmap to vector conversion
07-12-2012 #12
Hi Martin,
thanks for your comments. I was beginning to suspect that most or all of the conversion software needs some work to obtain unbroken geometries. the method I have used to date is to trace manually and then stick the tracing paper on the screen and follow the lines, clicking about every 2-3mm. I then use splines to smooth out the trace. I realize that this is time consuming, but still much better than anything I have done with the auto trace in serif. The logos i use are not other peoples logos, are drawn specifically for a friend, obviously not in a vector format. copyright does not come into it, but thanks for the warning.
Need help with a sensorless vector VFD and 2.2kw motor.
By kajuk in forum Spindles & Drive MotorsReplies: 42Last Post: 04-06-2015, 10:54 PM -
Build Log: Servo Drive and VFD with vector control
By Jonathan in forum Electronic Project BuildingReplies: 17Last Post: 05-04-2015, 07:58 PM -
By kajuk in forum Spindles & Drive MotorsReplies: 0Last Post: 29-01-2014, 06:09 PM -
Vector Linker , thermic cutting
By CNCtoolsWorld in forum Manufacturer NewsReplies: 0Last Post: 28-02-2013, 04:55 PM -
Vector graphics AKA CAD for free
By m.marino in forum Computer SoftwareReplies: 1Last Post: 15-01-2009, 02:17 AM
