12-12-2012 #2
You're going to need at least one end fixed to stop play in the leadscrew from the cutting forces. You could use a pillow block and 12mm ID bearing as your other support, I'd not recommend an SBR12 as it's not designed for that use.
What machining have you asked for on the ballscrews, or have you not ordered them yet?
WANTED: FK12 fixed ballscrew support
By r0bsk1 in forum Items WantedReplies: 0Last Post: 29-10-2013, 10:21 PM -
FOR SALE: sbr12 supported rod
By johngoodrich in forum Items For SaleReplies: 4Last Post: 25-04-2013, 10:49 PM -
I need some help, Dukitec FK15 support unt - torque of the nut onto the ballscrew
By range3rrr in forum Lead Screws, Nuts & SupportsReplies: 0Last Post: 09-04-2012, 11:20 AM -
Ballscrew Support Bearings - Angular or Self Align or ??
By williamturner1 in forum Lead Screws, Nuts & SupportsReplies: 8Last Post: 02-10-2010, 02:38 PM -
Machining Ballscrews with a mini lathe (& ballscrew support questions)
By HankMcSpank in forum Lead Screws, Nuts & SupportsReplies: 15Last Post: 16-02-2010, 12:22 AM
