Thread: Gerber system 48
29-07-2013 #61
Sorry picked you up wrongly, thought you meant that when the computer died you got the router upgraded, lets face it they are old lol.
So what is the spec of the computer you have it running on now?
How have you got the router connected to the computer & how have you got the dongle connected?
Think I still have the manuals for the system 48 at the unit somewhere, will have a hunt for them.
30-07-2013 #62
I am running windows 95 the same as the before the crash.
I have the dongles in place and the router cable is connected to Com port 1 exactly the same as before.
The CD with GA release 6.0- Rev.E was installed and all the programs are working. I design on composer then send to Artpath. Instantly I receive an error message-No Router installed, use GSP Setup.
I do that and still the same reply.
I can not get my router installed. Gerber tells me they don't support this product any more. I asked for software help.
I figured that should be in their library. Yet, no help at all.
I have a ton of work backed up and I am at wits end.
30-07-2013 #63
Perhaps the software is looking at Com 2 instead of Com 1. Sorry can't help more that that. Clive
30-07-2013 #64
30-07-2013 #65
Hope he has, nothing worse than having work piling up because of machinery problems. Have you checked that the com port is set up correctly?
Unfortunately I never ran the machine as it was intended for use as it had a faulty motherboard when I bought it.
If the guy in the states can't help then hopefully the manual will have some troubleshooting info.
I had the same problem with Gerber to be honest, like you I was looking for a bit of info as originally I was going to see if I could fix the machine rather than just rip out all the original electronics. Absolutely no help what so ever which has now put me off ever buying anything with their name on it.
30-07-2013 #66
11-09-2013 #67
13-09-2013 #68
The diode pic posted earlier in this thread is a general purpose 400v 35A diode so anything with 35A or more current rating will be fine, (I don't think you need 400v as its a 35v power supply so 100v rating should be fine, 400v are just more common) I think I still have them in my PSU which is still running my machine :-)
Regards
StuartLast edited by stuboy; 13-09-2013 at 12:36 PM. Reason: wrong text
gerber system 48 plus sizing problem
By nodgeruk in forum Machine DiscussionReplies: 1Last Post: 17-09-2014, 05:53 PM -
Gerber System 48 with Mach 3 software training required!
By Ahmed in forum Opportunities Available & SoughtReplies: 0Last Post: 07-11-2013, 08:56 PM -
gerber to dxf for PCBs
By Web Goblin in forum Computer SoftwareReplies: 4Last Post: 26-10-2013, 08:25 PM -
BUILD LOG: Gerber system 48 conversion
By martin54 in forum DIY Router Build LogsReplies: 14Last Post: 25-08-2013, 11:29 AM -
Gerber system 48 Plus router
By poppa jock in forum Machine DiscussionReplies: 0Last Post: 29-07-2013, 05:43 PM
