It seems that we have different opinions of what a LIMIT switch and a SAFETY switch are. Obviously safety switches should be dual circuit and fail-safe. A limit switch/sensor is usually a single switch that tells the PLC or machine computer its current position. So I guess the safest way is to have LIMIT switches near the end of travel and SAFETY switches just before the physical stops. I think we're both on the same wavelength, but not using the same terminology!
18-12-2012 #2
I may be talking tosh but this was a question that I asked when I first started thinking/designing my first machine. I got confused about home switches and limit switches and safety switches and I ended up having several physical work areas on my machine, depending on the size of the piece/part I was making, so if my machine sailed out of the physical working area I had defined, there was a good reason for it and it activated an E-stop shutting the machine down via the software stopping the program in its tracks, these physical working areas were movable/definable the in software, and a manual restart would be required whatever the condition, there were also a switches at the physical ends of all the axis, that was more brutal and just shut the power of completely. I even went and purchased a multiple input/output card (pokeys55) to achieve this. However as JAZZ has said all unexpected movement of an axis would imply a safety condition exists and should shut down the machine until it can be fully investigated..Rick
-10V to 10v circuit
By vre in forum General ElectronicsReplies: 17Last Post: 15-01-2014, 12:15 AM -
Spindle Stop?
By manofgresley in forum Spindles & Drive MotorsReplies: 21Last Post: 08-01-2013, 06:37 PM -
I promise I will stop asking daft question soon. Ish.
By D.C. in forum Gantry/Router Machines & BuildingReplies: 27Last Post: 15-10-2012, 11:37 PM -
wiring e-stop button
By deannos in forum General ElectronicsReplies: 10Last Post: 14-01-2012, 11:03 AM -
End mill depth 'stop' rings
By HankMcSpank in forum Tool & Tooling TechnologyReplies: 10Last Post: 24-02-2010, 02:03 AM
