27-08-2019 #1
Hi all,
Currently loving my machine but would like a smidge more cutting area so I've changed a few parts.
Here is how it currently sits. Y axis rails on 80x40 profiles which are bolted to a large 10mm thick aluminium plate.
I do get some vibration issues when milling. I can actually see swarf bouncing around on the aluminium base plate and the sound isn't great either.
I have a bunch of 40x40 aluminium profile i can use to make a "bed/base". How would this compare to the current build for rigidity?
Other things like steel gantry sides for bracing (to stop it tipping forward on the y axis) and steel side plates bolted to the frame to stop the y axis rails tipping inwards.
Would this help issues at all?
Neal
27-08-2019 #2
Hi Neal,
The gantry end plates and profile braces will help stiffen but not with 2mm tin sheet. You'll need 5mm plate at least.
Sent from my SM-T580 using Tapatalk-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
27-08-2019 #3
I would use a single piece of 5 or 6mm but if you already have the 2 mm plate then triple it up.
I would do both - the 10mm plate to act as the sub base to be tapped into for fixtures etc. then add the 40mm sections underneath ensuring they are joined to each other.. Adding another skin under the 40mm sections (even 2mm steel would be good) to make a sandwich.
But it won’t count for much unless you can tie the base to the sides. Do you need open access both ends ? Can one end be full height shear panel joining both sides and the base ? Or can the corners be triangulated at least rather than squared off as drawn.
28-08-2019 #5
Is this a working machine your trying to extend or just a design model your changing.?
Reason I'm asking is because you don't show ballscrews or any linear drive mechanisms for long axis.
Without knowing how this fastened/designed then not much point suggesting alternative ways to stiffen other than what you shown because more than likely clash.
28-08-2019 #6
Thanks very much. Yes i have loads of 2mm steel plate lying around. I'd rather use that than buy new stuff. Is this what you meant by use the 10mm plate AND the profiles? I have the 10mm plate bolted to the platform created by the profiles. Front view.
Now side view. IF I have enough profile i can lay them next to each other touching. But if not I will have to space them as in the second pic.
Thanks Jazz. Yes this is actually my current machine that I want to extend a little bit, but at the same time add a bit of rigidity. Don't get me wrong, it works great and I can get some decent cuts in aluminium, but I'd like to stiffen it up where i can, using what I have laying around. I removed the linear motion components to clear the clutter in the drawing so you could see which base and profiles i was referrring to.
28-08-2019 #7
What you've drawn now will do the job ok and about all you can do given the design. Just use stiff braces, tin sheet isn't good enough and while layering up will help, you could also get resonance from them unless fastened well.
To be honest I'd probably prefer to use 18mm or 12mm ply wood before 2mm tin sheet.
28-08-2019 #8
28-08-2019 #9-use common sense, if you lack it, there is no software to help that.
29-08-2019 #10
It would help with the lateral rigidity, but it wouldn't be as good as a single thicker plate, as the flexing stiffness (in the flat direction) of a plate increases as something like the 3rd power of the thickness. The thing is that stacked flat plates can slide over each other therefore don't increase the stiffness so much. One thing that might work is if you glued the 2mm plates together with high strength epoxy, this would likely also help with damping a bit, but is obviously a bit of a faff to do
MicroRouter Spindle upgrade - advice and help required
By ngwagwa in forum Spindles & Drive MotorsReplies: 16Last Post: 26-05-2019, 02:52 PM -
Rigidity of aluminium profiles and rectangular tube sections....
By Voicecoil in forum Gantry/Router Machines & BuildingReplies: 6Last Post: 14-10-2018, 01:51 PM -
profile rail and purchase advice
By johngoodrich in forum Marketplace DiscussionReplies: 2Last Post: 17-09-2016, 07:53 PM -
Low profile, compact work-holding solutions. Advice sought.
By Wal in forum Tool & Tooling TechnologyReplies: 23Last Post: 26-08-2016, 10:45 PM -
advice on upgrade to 5 axis control
By alanb in forum General ElectronicsReplies: 17Last Post: 27-07-2012, 06:29 AM
