07-04-2013 #1
Hi all..
Been a while since I was on this forum, have now moved into a council property, with no garage..! I have tried to build a wall mounted cnc but just cant get round the noise problem... So have decided to scale down to a small desktop cnc (400mm x 400mm). I could start chopping up my rails and ballscrews, but seems the wrong way to go about this...
I will compile a list of the stuff I have in more detail but roughly it is as follows;
2 x 2mt 20mm supported rail + 4 bearing blocks
2 x 1.4mt supported rail + 4 bearing blocks
2 x 25mm ballscrews (machined to fit nema 34 mounts)
2 x 25mm ballnuts
1 x 16mm ballscrew (machined to fit nema 23 mount)
1 x 16mm ballnut
2 x nema 34 mounts
2 x nema 34 motors (4 wire 6N motors)
70v PSU and two drivers for the nema 34's..
I will get specs and serial numbers etc later today or tomorrow...
As I mentioned, I am scaling down so these will be up for sale or swap..
Any more info needed, just ask!
Steve...
07-04-2013 #2
Could be interested in the 2 nema 34 pm me a price buddy
07-04-2013 #3
Hi D-man..
Just the motors? I have the mounts, drivers and psu that goes with them too...
Steve..
07-04-2013 #4
Yeah just the motors. Which drivers are they? Drop me a price for both bud
07-04-2013 #5
07-04-2013 #6
Bit bigger than I need but would have bought the job lot to save pissing about if it had been a tad smaller.
John S -
07-04-2013 #7
07-04-2013 #8
Hi all again..
Wow, did not expect such an enthusiastic response..
I have my hands full with kids today, will supply all specs by tomorrow morning for you all.. Have had several messages asking me for a price for the lot, I will also work this out for you all too..
If any of you are up-sizing, I will be interested in a swap for a smaller machine/or parts...
25mm ballscrews are 2mts usable thread + machined ends (10mm pitch)
16mm ballscrew is 1.4mts usable thread + machined ends.. (10mm pitch)
I have not included all the z axis bits yet so the list is quite incomplete, really need an hour or two to catalogue what I have, and the kids are not giving time to draw breath today..!
Bear with me until tomorrow and I will have all info on everything...
Steve..
07-04-2013 #9
Hi Dean..
Yes, 1,4mt rail is 20mm, more info to follow...
Steve..
08-04-2013 #10
Hi all...
Ok, think I have managed to compile a pretty comprehensive list.. All these parts were bought from Zapp and I have tried to pull the details from the invoice and match them to Zapp's website. I have put a link next to each item so you can check it out directly..
2 off - SK-A4-013 MBA-20F
Nema 34 motor mount
mba12c-nema-23-motor-mount
2 off - FKA20-C7 FKA20-C7
25mm Ballscrew support (fixed end)
The FKA20-C7 is a ballscrew support for the fixed end of the ball screw. (25mm diameter)
1 off - HL-K0-002 BF-12C7
16mm Ballscrew support (Floating end)
The BF12-C7 is a ballscrew support for the floating end of the ball screw. (15-16mm diameter)
2 off - ZPSFBN2510 SFBN2510
25mmx10mm pitch ballnut
SFBN2505
THIS LINK IS TO THE 25MMX5MM BALLNUT, CANT FIND 25MMX10MM ON WEBSITE
2 off - ZPSF2510-2200 ZPSF2510-2200
25mmx10mm pitch ballscrew - 2200mm long
SF2505
THIS LINK IS TO THE 25MMX5MM BALLSCREW, CANT FIND 25MMX10MM ON WEBSITE
2 off - CN-M0-019 SY85STH80-5504B
6NM stepper motors (Nema 34)
SY85STH80-5504B Nema 34 Stepper motor
1 off - ZPSF1610-1400 ZPSF1610-1400
16mmx10mm pitch ballscrew 1400mm long
SF1610 ballscrew
1 0ff - ZPSFBN1610 ZPSFBN1610
16mmx10mm ballnut
SFBN1610
1 off - FK12-C7 FK12-C7
16mm ballscrew support (fixed end)
The FK12-C7 is a ballscrew support for the fixed end of the ball screw. (16mm diameter)
1 off - SK-A4-001 MGD16
16mm Ballnut bracket
The MGD is a ballnut bracket desiged to fit standard (DIN 69051) FSU nd FDU ballnuts
2 off - BF1-15.875X19.D40L66 BF1-15.875X19.D40L66
Nema 34 flexible coupling (drilled to fit ballscrew and motor shafts)
BF1-D40L66 Flexible Coupling
2 off - HL-K0-011 BF-20
25mm ballscrew (floating end)
The BF20-C7 is a ballscrew support for the floating end of the ball screw. (25-32mm diameter)
2 off - SK-A4-003 MGD25
25mm Ballnut bracket
The MGD25 is a ballnut bracket desiged to fit standard (DIN 69051) FSU nd FDU ballnuts
2 off - HL-G0-1400-20-002 TBR20-1400
20mm supported rail 1400mm long
TBR20 Supported Round Shaft
8 off - HL-I0-013 SBR20-UU
Open linear bearing for 20mm supported rail
SBR20UU Open linear bearing with housing
2 off - HL-G0-2000-20-002 TBR20-2000
20mm Supported rail 2000mm long
2 off - HL-J0-400-20-001 ZPSFC20-400
Ground round shaft 20mm dia
SFC20 Precision ground round shaft (20 mm)
1 off - HL-E0-500-16-05-001 ZPSF1605-500
16mmx5mm pitch ballscrew (z axis) 500mm long
R1605 ballscrew
1 off - FK12-C5-TMT FK12-C5-TMT
The FK12-C5 is a ballscrew support for the fixed end of the ball screw. (16mm diameter)
4 off - HL-K0-015 SHF-20
20mm ground shaft supports
SHF-20 flange mounting rail support
4 off - HL-I0-003 SMA20UU
20mm ground shaft linear bearings
SMA20UU Linear Bearing with housing
Phew... That's just about it... I did not include the two nema 23 (3NM) motors or mounts as I am thinking of using them for my smaller cnc, but if you insist, then I will sell them too to make the package complete.
Also not listed here is the price I paid for machining the ends of the ballscrews (£320).
There are also 2 x PM752 drivers for the NEMA 34 motors. These seem to be discontinued on the Zapp site now but I did find the data sheet for them http://www.zappautomation.co.uk/down...vers/PM752.pdf
These cost me about £70 each, but am still trying to find the invoice for them..
This equipment has had about a years very light use, mainly engraving wooden boxes.. I have only used my router for wood and it has had only light engraving loads. I have cleaned everything, including dismantling the ballnuts and reloading them with new ball bearings.
A couple of you have asked me if I still have the gantries and z axis assembly. Unfortunately, I dont think that what I have will be of any use to you as I had to make a 12" high gantry to accommodate pre assembled boxes (which I engraved) for a customer. This meant the gantry was way too high to be rigid enough for 'proper' routing and was only capable of light loads. I was my intention to lower the gantry with a new design which meant mounting the rails (X) onto a hefty pair of RSJ's.
If anyone is interested, I still have these RSJ's (cost me £100 for the pair), they are 157mm square and just shy of 2 meters long. They have been drilled to take the supported rails on one side, and have 6 x 1/2" mounting holes on the other side. They are extremely strong and rigid and I reckon they will make very good mounting rails for the X axis. Will supply photos on request.
Whole lot cost me around £2700 inc vat...
Make me an offer for the lot, or will split if no takers for the whole package..
Any questions, just ask...
SteveLast edited by fasteddy; 08-04-2013 at 11:21 AM.
Router bits for use with Slate
By habibuzziwa in forum Tool & Tooling TechnologyReplies: 1Last Post: 30-06-2013, 06:12 PM -
3.175mm router bits
By ian stenson in forum Tool & Tooling TechnologyReplies: 2Last Post: 13-06-2013, 07:59 AM -
SWAP: 6mm Carbide CNC Router Bits for 3mm's
By Fivetide in forum Items For SwapReplies: 8Last Post: 04-12-2012, 04:47 PM -
Router costs (part 93 - Bits)
By mocha in forum Tool & Tooling TechnologyReplies: 3Last Post: 29-05-2012, 10:23 PM -
CNC Router Bits
By ploughex in forum Milling Machines, Builds & ConversionsReplies: 4Last Post: 01-08-2010, 06:26 PM
