Not really the relay contacts because it's a NO relay and when signal drops power to relay coils the contacts break naturally ( Unless faulty in which case it won't stop anyway.!)
It's the control software or more accurate the signal state you can't trust and in extreme case's it's possible it could switch state thru noise interference.!!
You could build into the Macro some conditional checking like checking the state of a input. This could be done by using double throw relay which sets a spare input used has a NOT-READY-NO-GO
This is one of the reasons for using a M6 tool change macro. It's in this macro where you'd put code for things like auto tool changers etc and also for doing safety checks like this if needed.! (could even turn kettle on for you for quick brew between changes. . Lol)
18-12-2012 #2
Exactly, I realise the relay contacts in play will be NO ...but it's the software/circuit that drives the coil I worry about...this is why I figured some condition dependent time delay would be brought into play here on the relay circuit ...therefore if a transient occured (in software or the control board), the spindle wouldn't kick into life straight away ...ultimately, I kinda seek a beep-beep-beep (like bin truck reversing sound), a couple of seconds before the spindle starts ...that way if I hear beep-age, I know to get my hands off the spindle sharpish!
18-12-2012 #3
EMCO Spindle Control
By Pete92 in forum Spindles & Drive MotorsReplies: 1Last Post: 06-11-2013, 10:20 PM -
PCPPS B.O.B. - OK for spindle control?
By birchy in forum Spindles & Drive MotorsReplies: 4Last Post: 09-09-2013, 12:50 AM -
Spindle Speed Control
By cncJim in forum Spindles & Drive MotorsReplies: 15Last Post: 18-06-2013, 07:53 PM -
Newbie. Questions about design software and machine control software
By MTech in forum Computer SoftwareReplies: 2Last Post: 11-12-2012, 12:58 PM -
Help with spindle control
By wizzy in forum Spindles & Drive MotorsReplies: 4Last Post: 12-02-2011, 12:51 AM
