Thread: Cambam / milling Alu
I have not tested this yet, as I am changing my X axis rails and cutting bed.
Using CamBam, how do you set the cutting profile to "spiral down" instead of plunge ? I cannot find any way of setting a "spiral or ramp" down move. The plunge feedrate is set as default to 300. The only thing I can find is the menu "Lead in move" with the 3 settings....Spiral angle / Tangent radius and Lead move feedrate. I haven't got a clue how much to set these at (if this is it) and/or if I need to change the plunge rate to 0 ??Swedish Storbro Luna - 3 axis CNC mIll - 250 - 2500rpm / 1.1 tonne
23-12-2012 #2
Sorry don't use Cam Bam so not much help.! The fact the lead in move has a spiral angle option suggests it does but how I've no idea.! Sure it will be a simple selection option.?
Are you using the free version.? If so then it may be disabled.
Setting rapids in CamBam
By swisscheese in forum CAD & CAM SoftwareReplies: 4Last Post: 04-04-2014, 02:30 PM -
Hobby-CNC Workflow - SKETCHUP + CAMBAM + MACH3
By WandrinAndy in forum Computer SoftwareReplies: 23Last Post: 04-10-2013, 02:53 PM -
Mach3 / cambam
By dudz in forum Artsoft Mach (3 & 4)Replies: 5Last Post: 01-04-2013, 06:02 PM -
Drilling Acrylic with CamBam
By m.marino in forum Machine DiscussionReplies: 2Last Post: 06-06-2012, 04:45 PM -
How do i make this in cambam?
By motoxy in forum CAD & CAM SoftwareReplies: 4Last Post: 09-02-2012, 06:01 PM
