Yes done that, balls everwhere.
Give the balls and nut a good clean before you start. Count the ball and seperate them into two equal amounts so that you get the same amount in each chain. Hoefully the ballnut has only two chains. What i used was a long pair of tweezers to replace the balls. I also stuck them in a little bit of grease to "glue" them in place when putting them back.
As Martin says there was a thread on this a while ago. A few of us have done it already.
The Following User Says Thank You to Web Goblin For This Useful Post:
20-12-2012 #2
I've done this a couple of times...
Ideally you want a tube which is the pitch diameter of the ballnut minus the diameter of one ball, so if you imagine the nut fully populated it would just slide inside. You can then hopefully gradually slide the tube in, position the balls in the tracks with tweesers and grease to make them stick. With all the balls inside and the retaining tube, it will be the same as having a new nut, so you just push the tube up against the end of the screw and carefully twist the nut back onto the screw ensuring that the tube doesn't loose contact, else the balls may drop out. You can also try putting the balls in with the nut on the end of the screw and turning it as you go, that's worked for me once.
If you've got a strong magnet then stick it to the side of the ballnut, so when you put the balls in they will just stick to the nut. Ideally, I think you should demagnetise the nut afterwards. Obviously with any of these methods ensure everything is very clean before you start since swarf or just about anything except grease/oil in the nut will damage it over time, and it's sensible to do it in a tray as the balls are bound to fall out again!
On the plus side, it's a good opportunity to clean the ballnut! I've known ones I've got from chai to have small bits of metal floating around in them, which really doesn't help, especially when trying to get zero backlash by preloading...
The Following User Says Thank You to Jonathan For This Useful Post:
angular contact bearings - back to back, further apart
By dsc in forum Linear & Rotary MotionReplies: 16Last Post: 05-01-2014, 10:59 PM -
ballnut - balls back in via the side cover and using less balls than original
By dsc in forum Lead Screws, Nuts & SupportsReplies: 9Last Post: 16-11-2013, 04:27 PM -
Balls, balls and balls
By Swarfing in forum Marketplace DiscussionReplies: 15Last Post: 21-03-2013, 08:45 PM -
X2 change balls crews or not?
By Oldie45 in forum Sieg Milling MachinesReplies: 7Last Post: 17-08-2011, 07:55 PM -
Lost my balls!!!
By danielbriggs in forum Lead Screws, Nuts & SupportsReplies: 26Last Post: 19-08-2010, 02:41 PM
