  1. #7
    I guess we have all done that! First make a cardboard tube, just roll up thin card, to go over the machining on the screw but will fit in the nut with the balls in. I used the magnets but found that thick grease held the balls in better. you will need a small screwdriver with a dab of grease on the end to place the balls inside the nut. When you have all the balls in place gently push in the tube. I rolled the tube up slightly smaller, pushed it in and let it expand. Then slide that sucker on. have fun.
    Bruce
    HA! jonathan beats me by seconds........
    The more I know, I know, I know the less. (John Owen)
  2. The Following User Says Thank You to motoxy For This Useful Post:
  1. angular contact bearings - back to back, further apart
    By dsc in forum Linear & Rotary Motion
    Last Post: 05-01-2014, 10:59 PM
  2. Replies: 9
    Last Post: 16-11-2013, 04:27 PM
  3. Balls, balls and balls
    By Swarfing in forum Marketplace Discussion
    Last Post: 21-03-2013, 08:45 PM
  4. X2 change balls crews or not?
    By Oldie45 in forum Sieg Milling Machines
    Last Post: 17-08-2011, 07:55 PM
  5. Lost my balls!!!
    By danielbriggs in forum Lead Screws, Nuts & Supports
    Last Post: 19-08-2010, 02:41 PM
