Page 5 of 8 FirstFirst ... 34567 ... LastLast
  1. #41
    What grease do I use for bearings and ballscrew nuts? Didn't realise but some if mine are running dry at the moment!
  2. #42
    http://www.mycncuk.com/forums/linear...on-grease.html
    Basically it's not that important for a light-duty machine. I just clean the ballscrews every so often with a rag damped with a bit of gearbox oil (75W-90). Rails too.
  3. #43
    Quote Originally Posted by Shinobiwan View Post
    Ballnut Lubrication / Grease - MYCNCUK
    Lubrication (OOooeerr missus) - MYCNCUK
    and if your still not sure: Metal Working Lubricants, Coolants and Fluids - MYCNCUK
    .Me
    Thanks guys. Motor oil works a treat.
  5. #45
    Motor oil might be a bit to heavy, plus the other thing you will need to keep an eye on is the swarf/dust sticking to the oil/grease on the screws which won't do the bearings a lot of good.
  6. #46
    I'm using 10w/40 which is pretty light when you just coating the rails and screws. I agree with the sticky problem though! My Y and Z are well out the way but the X needs regularly cleaning. I use wd40 for that and works fine although tedious.
  7. #47
    WD40 would probably work fine for lubricating it as well, not sure if it would be possible to fit some sort of bellows over the ballscrews to help keep dirt & dust levels down. Sure there must be something available off the shelf that would do the job.
  8. #48
    Loving the speed and ease of the CNC. Got done in a week what would normally take a couple of months!
    Now I just need a CNC spraying machine hmmm...
ID:	8236   Click image for larger version.
ID:	8237   Click image for larger version.
  9. #49
    Quote Originally Posted by martin54 View Post
    But not for very long as it evaporates quickly at room temperature.
  10. #50
    FLIPPING HECK!!!!! Where are those speakers supposed to go. Not sure I could even fit them through the front door. Look gorgeous mind.
    The more I know, I know, I know the less. (John Owen)
  1. Bridgeport Retrofit motion control?
    By drumsticksplinter in forum Milling Machines, Builds & Conversions
    Last Post: 28-03-2015, 11:00 PM
  2. Conect 121 Retrofit
    By Sooty in forum Lathes, Lathe Rebuilding & Conversions
    Last Post: 17-02-2015, 11:45 PM
  3. VFD retrofit Hobbymat BFE65
    By manofgresley in forum Milling Machines, Builds & Conversions
    Last Post: 13-09-2013, 05:07 PM
  4. Boxford 125 CNC retrofit advice
    By pneanvil in forum Boxford Lathes
    Last Post: 05-12-2012, 11:47 PM
  5. Motor size 23' and 2/1 reduction for Z axe on SX3 retrofit.
    By A2P in forum Linear & Rotary Motion
    Last Post: 15-09-2010, 05:14 PM
