Don't plunge into Ali it knocks hell out the machine and cutter.!!
Here's 2 bits of code to try using a spiral entry both same except ones conventional milling and the other Climb milling so you can see difference.!
cutting 50mm Dia circle, 3mm deep, 1mm Doc, 4mm S-flute cutter, 15000rpm, 800mm/min, 400mm/min spiral down. Z zero top of material.
Edit: Rapid height =10mmLast edited by Lee Roberts; 21-12-2012 at 12:04 AM. Reason: moved post from another discussion, so cleaned this one up a little
Anyone got some 2.5D G-code please ?
By dudz in forum Programmers CornerReplies: 5Last Post: 22-06-2013, 11:21 PM -
Cambium Code Web Tools – Parametric G-code Generation
By CambiumMachines in forum Manufacturer NewsReplies: 0Last Post: 09-01-2013, 04:56 AM -
Pros and cons of climb milling in wood
By Richie in forum Wood Finishing Tips & TricksReplies: 15Last Post: 14-06-2012, 05:09 PM -
G Code help
By moose007 in forum Programmers CornerReplies: 4Last Post: 22-05-2009, 11:39 AM -
G & M Code Tables for Milling
By Lee Roberts in forum Programmers CornerReplies: 0Last Post: 14-10-2008, 02:30 AM
