    Rye's Avatar
    Lives in Sheffield, United Kingdom. Last Activity: 16-02-2019 Has been a member for 9-10 years. Has a total post count of 50. Received thanks 4 times, giving thanks to others 0 times.
    I usually cut acrylic with 1 mm passes using a 3.175mm single-flute @ 1050 mm/min - somewhere between 10000-13000 rpm (i think). Will be cutting some tomorrow. Will post RPM here.
    Bought a Chinese 6040...if only I'd known better :(
    Quote Originally Posted by Rye View Post
    I follow 50%+ rule of DOC which was 2mm in for 1/8" will try less. Going to buy decent Trend bit 1/4" 6.35mm
    Rye's Avatar
    Quote Originally Posted by Tom J View Post
    Cut some 4mm acrylic today using a 4mm shank/3 mm dia cut single-flute shop-apt bit. Did two passes @ just under 2mm on each with a finish pass. Feed rate 1200 mm/min with spindle speed around 13200 rpm (220 hz). Cut fine leaving a nice finish (just a couple of tool marks on one side.) Not saying that's the correct or optimal speed, but it worked for me. Usually I stick to smaller passes because I have a habit of not properly sticking/securing the acrylic to the spoil; and there's nothing worse than spending ages engraving acrylic just to have it lift from the table when cutting :)
  1. Acrylic or mdf I can cnc
    By rainboweyes in forum Opportunities Available & Sought
    Last Post: 19-02-2013, 02:09 AM
  2. Laser cutting 10mm acrylic?
    By camhguh in forum Laser Machines & Building
    Last Post: 04-09-2012, 12:51 AM
  3. Drilling Acrylic with CamBam
    By m.marino in forum Machine Discussion
    Last Post: 06-06-2012, 04:45 PM
  4. Which end mill to level my acrylic bed?
    By HankMcSpank in forum Tool & Tooling Technology
    Last Post: 03-02-2012, 02:57 PM
  5. Acrylic suppliers
    By Web Goblin in forum General Discussion
    Last Post: 24-10-2011, 09:11 PM
