Thread: Paints and finishes
Wilfy, quick search seemed to indicate that the paint was associated with Jawel & all info relevant to their 2k paints, this link gives all the details plus a guide on spray settings.
Jawel Paints online ordering for Car Paint, Tools and Equipment.Technical data sheets.
End of the day it's only you who can decide & anyone who told you it would be ok for a little job would be wrong to do so in my opinion. Normally problems with stuff like this is due to long term exposure rather than a once in a while use but there is always a risk even for occasional users. Personally I would use a water based acrylic paint, finish might not be as good but it would be good enough for me. Pretty sure you could still get a finish you would really be proud of with a different type of paint if you used some of the finishing products/techniques that have been mentioned by Chris.
28-12-2012 #2
Wilfy, I'm at the same stage as you regards painting an mdf product.
Sorry I don't know the answer to the above question but on my project, I've decided to go with the flocked foam rollers I linked in your earlier thread. I'm using standard water based acrylic primer, 1 coat on edges first, then 2 coats all over with sanding inbetween. For the top coats I've decided to use plain old non drip gloss with the same rollers, 2 stretched out coats with light sanding. I've started priming and sanding and soon should have paint on something so you could see the finish I get and maybe follow. If the gloss flattens out as I hope I should get a nice flat shiny finish, as the prep work will be of high quality.
Cheers Adil
28-12-2012 #3
hmmm.. i understand the concern regarding using that paint, but the fact is, i have it, ive used it before i wore a suitable mask previously and that was the only precaution i took, if i use it again i'm confined to a garage this time, i'm happy to wear a disposable fully body suit and will discard any clothes i spray with before i enter the house + i will have another mask to use.
all i want to do with this paint is lacquer my desk after spraying it with hopefully some cheap spray cans. if i cant do it this way the cost of paint for my desk is going to go from about £15 to £50+ and leave me with a lot of paint i dont need and will likely not use again for another number of years again.
