Thread: Paints and finishes
26-12-2012 #11
Hi Chris, most impressive. New grill really does improve the looks (bit more like the XKR!! ). Three days to clear the swirls-wow-guess mine will have to stay a bit swirly. Thanks for your comment about problems, the only probllem I have is a fault light on the active cc that the auto electrician cannot clear. He has tried a new radar unit and a new ECM, to no avail. He is now checking out the loom. Each effort seems to clear the fault, only for it to reappear after about 20 miles or so. The AE is a bit of a jag spcialist, but is struggling. The car has done about 72K and has always been maintained. any suggestions would be welcomed. Note to the Mod, Iam aware this is a cncsite, not Jag!! sorry, but I need any help I can get. Regards, Geoff.
26-12-2012 #12
Geofrey, they need to add another section like the signmaking forum I use. They have an off topic section where you can pretty much talk about anything you want to, with something like that you can discuss Jaguar or anything else you want without feeling you are upsetting anyone & not hijacking other threads lol.
28-12-2012 #13
28-12-2012 #14
Wilfy, quick search seemed to indicate that the paint was associated with Jawel & all info relevant to their 2k paints, this link gives all the details plus a guide on spray settings.
Jawel Paints online ordering for Car Paint, Tools and Equipment.Technical data sheets.
End of the day it's only you who can decide & anyone who told you it would be ok for a little job would be wrong to do so in my opinion. Normally problems with stuff like this is due to long term exposure rather than a once in a while use but there is always a risk even for occasional users. Personally I would use a water based acrylic paint, finish might not be as good but it would be good enough for me. Pretty sure you could still get a finish you would really be proud of with a different type of paint if you used some of the finishing products/techniques that have been mentioned by Chris.
28-12-2012 #15
Wilfy, I'm at the same stage as you regards painting an mdf product.
Sorry I don't know the answer to the above question but on my project, I've decided to go with the flocked foam rollers I linked in your earlier thread. I'm using standard water based acrylic primer, 1 coat on edges first, then 2 coats all over with sanding inbetween. For the top coats I've decided to use plain old non drip gloss with the same rollers, 2 stretched out coats with light sanding. I've started priming and sanding and soon should have paint on something so you could see the finish I get and maybe follow. If the gloss flattens out as I hope I should get a nice flat shiny finish, as the prep work will be of high quality.
Cheers Adil
28-12-2012 #16
hmmm.. i understand the concern regarding using that paint, but the fact is, i have it, ive used it before i wore a suitable mask previously and that was the only precaution i took, if i use it again i'm confined to a garage this time, i'm happy to wear a disposable fully body suit and will discard any clothes i spray with before i enter the house + i will have another mask to use.
all i want to do with this paint is lacquer my desk after spraying it with hopefully some cheap spray cans. if i cant do it this way the cost of paint for my desk is going to go from about £15 to £50+ and leave me with a lot of paint i dont need and will likely not use again for another number of years again.
28-12-2012 #17
OK let me put it this way Wilfy, I know quite a few mechanics who have been using 2k paints for donkeys years mostly without much in the way of protection & they are all alive & well, none of them were aware of any real risks when they started & most of them still use 2k paint & will probably continue to do so as long as they can get it. BUT the risks that are associated with these paints are now known about so it would be irresponsible for me to say "go ahead & use it you will be fine for a small job like this"........ That's your choice to make. In all honesty if I had it lying about I would probably use it myself but then during 20 years in the RN I was exposed to all sorts of nasty stuff that now requires some serious health & safety precautions.
1want1, long as you make sure the surface is good before you apply any primer/undercoat & you rub it down & fill any gaps after the first primer coat then you should be fine. Biggest mistake people make is to think the paint will hide minor imperfections but in actual fact in most cases it just highlights them lol. Don't buy a cheap top coat & if you are using a normal houshold gloss on something like a table then it will really need some sort of hard clear coat over the top. Water based acrylics are good but they are not cheap.
