28-12-2012 #8
The object was not to stop people from thinking for themselves, rather to encourage people to be able to produce a starter machine that has been expertly designed to eliminate some of the more common pitfalls, rather than help dig them out afterwards!!!
To promote discussion about general requirements for such a machine listing the pros and cons of various parameters and consider the cost/benefit of each idea. I am not suggesting that one size fits all, only that for a starter machine the requirement is fairly universal.
Yes, there are already enough designs and kits already available, but from many comments on this site it would appear that none of them are that good.
Many of the constructive comments made on build logs would seem to be about rail and gantry short comings, and most are generally fairly similar. I am sure we have enough expertise on this site to overcome most of these problems
If the first involvement with cnc leads to a successful machine build, surely that is better than a perhaps dubious purchase from elsewhere?
The machine design is only the fist step on what is a steep learning curve, the actual build, wiring cad cam and machining still have to follow.
Not everybody wants to start with a small (hopefully inexpensive) machine, but many do.
Not everybody with an interest in making things has an engineering background, the idea was to make it easier for one to get started and once bitten by the cnc bug who knows what could develop? G.Last edited by GEOFFREY; 28-12-2012 at 01:09 AM. Reason: typing again
BUILD LOG: starting from scratch- router 1st project
By idefix in forum DIY Router Build LogsReplies: 24Last Post: 10-01-2014, 12:53 AM -
BUILD LOG: My first project: A fast router...
By Boscoe in forum DIY Router Build LogsReplies: 13Last Post: 14-08-2013, 09:34 AM -
Project CNC Router for all
By Anónio Pinho in forum Open Source Designs & PlansReplies: 0Last Post: 30-06-2012, 01:31 AM -
NEW MEMBER: New to MyCNCuk
By m1ptr in forum New Member IntroductionsReplies: 5Last Post: 28-03-2012, 02:47 PM -
Much advice needed for an 8' x 4' cnc router project / and vacuum table
By FlightCaseCo in forum General DiscussionReplies: 1Last Post: 01-01-2012, 12:34 AM
