    I think the purpose of a starter machine is to:
    1) provide a machine which is known to be fully compatible and working.
    2) be cost effective
    3) require minimal skill level
    Suppliers, materials and software need to be specified to guarantee compatibility.
    The machine should not be over-specced and all parts should be fully utilised.
    Precision parts should be bought off the shelf with the only fabrication requiring basic hand tools where possible.
    Like so many people state on here - you need to specify exactly what your goals are before you can hone in on the solution.
  2. The Following User Says Thank You to Spedley For This Useful Post:
  3. #2
    I don't think it matters what your goals are, there will always be too many of them for a group project.
    The thread is 6 months old now and so far has got nowhere and sorry to say this but it never will.
    Only way a machine will get built is if one person decides to build what 'he' thinks is right and offers it for sale.
    Then all the cheap arsed vultures will gather and pull holes in it and reckon it's too expensive and you could do it cheaper.
    However missing the point that they are still weld to the fence, not sat on it.
    John S -
    John, I agree with most of your sentiments, and the idea was never to try to "design a machine by committee", merely to come up with a set of general parameters for a starter machine and then for one person to "run" with it. There are certainly enough people on this forum that could do that if they wanted to.
    Of course there would be critics - does that really matter? This thread has been dormant for the last six months just because
    of such comments, and I only reintroduced it because there have been several posts from people asking about about small starter machines/kits etc. G.
  5. #4
    Quote Originally Posted by GEOFFREY View Post
    So what parameters would you suggest? Lets see if 1% or 2% of people agree with them...
    Tempting...
    I will post the drawings for a medium size machine I've designed soon, but I doubt anyone would use them since you can't make it without a milling machine & CNC router & lathe, which is likely to be a problem with any general design people come up with here.
  6. #5
    If you can minimise and simplify the pieces requiring milling/turning then these could be supplied by people on the forum. I often reads posts on here where people are asking for parts cut, why not pre-defined parts for the cnc machine?
  7. #6
    Quote Originally Posted by Spedley View Post
    Exactly my thoughts re "by the people for the people", once we know what parts need making and the demand, some people maybe happy to do like a batch of the same part with something like a minimum amount, it dosnt need to be done for free but could be done with the intension of covering costs and to help people, rather than looking to turn a profit.
    I dont think offering yet another commercial machine is the way to go, (open source, with a little help from my friends) seems like the right way of describing it.
    .Me
    At least we do seem to be getting a few positive ideas - maybe it will exceed "J's" 1 - 2%. I am looking forward to seeing your new design Jonathan, but do suspect that it will fall outside of the "starter" category. When I started this thread I knew that it would be contraversial, but had hoped that one of the more experienced members might be prepared to give it a go. the basic parameters were discussed some time ago, but were not finalised. The idea is to open up discussion about the requirements of a smallish robust uncomplicated "starter" machine and then hope to find that a project manager/coordinator could make the final design decisions and decide on materials suppliers etc. There is absolutely no doubt in my mind that with the mathematical prowess of people like Irving and Jonathan, engineering skills of people like Jazz and John S and the dogged determination of people like myself we could soon have the best machine plan/kit available. In mentioning names I hope that I have not offended anybody, I was only referring to "people like" as I am aware that the forum has many other highly skilled and knowledgeable members. G
  1. BUILD LOG: starting from scratch- router 1st project
    By idefix in forum DIY Router Build Logs
    Last Post: 10-01-2014, 12:53 AM
  2. BUILD LOG: My first project: A fast router...
    By Boscoe in forum DIY Router Build Logs
    Last Post: 14-08-2013, 09:34 AM
  3. Project CNC Router for all
    By Anónio Pinho in forum Open Source Designs & Plans
    Last Post: 30-06-2012, 01:31 AM
  4. NEW MEMBER: New to MyCNCuk
    By m1ptr in forum New Member Introductions
    Last Post: 28-03-2012, 02:47 PM
  5. Replies: 1
    Last Post: 01-01-2012, 12:34 AM
