Thread: Limit Switches with LED's
01-01-2013 #15
An Operational Amplifier is wonderful thing. It has 2 inputs labled + and -. If the Voltage on plus is higher than the Voltage on minus the output pin goes high, vice versa and it goes low. With a bit of resistor jiggery pokery you can multiply or divide a voltage by anything you like.
If they make an Op amp and it turns out to be too clunky they mod the circuit to lose the drive high on the output and call it a comparator. You connect your input to one pin, a reference Voltage to the other and the output tells you which is the higher.
GUI usually stands for Graphical User Interface.
I can't comment on your circuit because I still don't know what is coming out of the Bob.
The Following User Says Thank You to Robin Hewitt For This Useful Post:
EMC2 home/limit switches... only acting as limit?
By vputz in forum LinuxCNC (EMC)Replies: 4Last Post: 15-10-2014, 09:51 AM -
Limit Switches
By Leadhead in forum General ElectronicsReplies: 1Last Post: 16-10-2013, 10:41 AM -
Limit switches and Mach3
By cropwell in forum Artsoft Mach (3 & 4)Replies: 1Last Post: 06-03-2013, 10:51 AM -
Uniport and limit switches.
By D-man in forum General ElectronicsReplies: 14Last Post: 13-02-2012, 11:37 PM -
Limit Switches
By Lee Roberts in forum General ElectronicsReplies: 13Last Post: 27-06-2008, 02:21 AM
