29-12-2012 #10
Right, so you have said let:
acceleration =1000mm/s^2=1m/s^2
velocity = 10m/min = 10/60= 0.167 m/s (not actually required for the initial calculation)
mass = 80kg
It's just newtons 2nd law, so F=ma=80*1=80 Newtons (equivalent to lifting about 8.2kg), so not far off my earlier estimate.
From the motor's point of view it's not 80N, since we have to consider the ballscrew in between. The ballscrew gives the motors a huge mechanical advantage. The relevant formula, which can be derived from considering the ballscrew as a ramp, is:
T=F*p/(2*pi*e)
Where T is the torque, F is the force applied to the nut, p is the ballscrew pitch (so 10mm=0.01m) and e is the efficiency (about 0.9). So chuck the numers in:
T=80*0.01/(2*pi*0.9)=0.14 Nm
So changing direction at 10m/min and 1m/s, as you describe, only translates to an extra 0.14Nm torque on the ballscrew, compared to going at a constant speed and 80N force on the ballnut.
The Following User Says Thank You to Jonathan For This Useful Post:
Maximum length guideline for a standard 16mm ballscrew?
By WandrinAndy in forum Lead Screws, Nuts & SupportsReplies: 5Last Post: 01-11-2012, 12:27 AM -
RFQ: Machining mounts in 80x40 profile for FK ballscrew supports
By Shinobiwan in forum Projects, Jobs & RequestsReplies: 1Last Post: 20-03-2012, 12:49 AM -
RFQ: Nema 23 motor mounts
By luke11cnc in forum Projects, Jobs & RequestsReplies: 14Last Post: 06-10-2011, 02:21 PM -
FOR SALE: MDF NEMA 23 Motor mounts
By Tom in forum Items For SaleReplies: 40Last Post: 21-08-2010, 01:23 AM
