Thread: What size clamping holes ?
30-12-2012 #3
Great thanks Jonathon.
I have drilled the holes 10mm deep. hope this is enough.
I know when I used to build motorcycles 20 years ago, it was unadvisable to put stainless bolts into Alu unless you coated the threads in copperslip first, as over time the stainless would weld itself to the Alu. So I guess you all use mild steel bolts to mount the rail bearings to the table ?Last edited by dudz; 30-12-2012 at 04:58 PM.
Swedish Storbro Luna - 3 axis CNC mIll - 250 - 2500rpm / 1.1 tonne with Heidenhein TNC155A controller.
Clamping Jigs
By Washout in forum Tool & Tooling TechnologyReplies: 4Last Post: 03-03-2014, 09:54 PM -
T-slot clamping accessories
By Neale in forum Tool & Tooling TechnologyReplies: 2Last Post: 16-02-2014, 07:48 PM -
Clamping question
By dudz in forum Metalwork DiscussionReplies: 6Last Post: 26-01-2014, 09:56 PM -
Stepper shaft size and pulley bore size problem
By psiron in forum Linear & Rotary MotionReplies: 13Last Post: 15-06-2010, 04:11 PM -
Some great DIY clamping setups
By Yohudi in forum Computer SoftwareReplies: 2Last Post: 22-01-2009, 06:54 PM
