  1. #7
    dudz's Avatar
    Lives in Dunedin, New Zealand. Last Activity: 09-02-2025 Has a total post count of 295. Received thanks 2 times, giving thanks to others 79 times.
    I still need to work on my drilling methods. When I used the counterbore endmills it seemed to cut with ease. When I drilled the holes with 5mm and 6mm HSS bits, it screamed like a "B$*ch" . Im not sure if I had the feedrates etc correct. Sounded like the Bits were blunt to me. / plunge rate 0 / Cutfeedrate 800 / Peck 2mm / spindle speed (I tried 8000 - 15000 ) / Target depth -11mm / tool dia 4mm and 6mm / used cutting fluid and air.
    Where do I put the input "400mm/min" for spiral down ?? can't find this in cambam for drilling (only for pockets and profiles), only cut feedrate in drilling .
    Swedish Storbro Luna - 3 axis CNC mIll - 250 - 2500rpm / 1.1 tonne
  1. Clamping Jigs
    By Washout in forum Tool & Tooling Technology
    Last Post: 03-03-2014, 09:54 PM
  2. T-slot clamping accessories
    By Neale in forum Tool & Tooling Technology
    Last Post: 16-02-2014, 07:48 PM
  3. Clamping question
    By dudz in forum Metalwork Discussion
    Last Post: 26-01-2014, 09:56 PM
  4. Stepper shaft size and pulley bore size problem
  5. Some great DIY clamping setups
    By Yohudi in forum Computer Software
    Last Post: 22-01-2009, 06:54 PM
