    dudz's Avatar
    Lives in Dunedin, New Zealand. Last Activity: 06-06-2026 Has a total post count of 295. Received thanks 2 times, giving thanks to others 79 times.
    Great thanks Jonathon.
    I have drilled the holes 10mm deep. hope this is enough.
    I know when I used to build motorcycles 20 years ago, it was unadvisable to put stainless bolts into Alu unless you coated the threads in copperslip first, as over time the stainless would weld itself to the Alu. So I guess you all use mild steel bolts to mount the rail bearings to the table ?
    Swedish Storbro Luna - 3 axis CNC mIll - 250 - 2500rpm / 1.1 tonne with Heidenhein TNC155A controller.
    You'd be better drilling the thru holes then they don't fill with swarf or chips. If you can't do that then think about removable plugs or set screws.
  1. Clamping Jigs
    By Washout in forum Tool & Tooling Technology
    Last Post: 03-03-2014, 09:54 PM
  2. T-slot clamping accessories
    By Neale in forum Tool & Tooling Technology
    Last Post: 16-02-2014, 07:48 PM
  3. Clamping question
    By dudz in forum Metalwork Discussion
    Last Post: 26-01-2014, 09:56 PM
  4. Stepper shaft size and pulley bore size problem
  5. Some great DIY clamping setups
    By Yohudi in forum Computer Software
    Last Post: 22-01-2009, 06:54 PM
