Thread: PSU question
There is a wonderful gizmo called the "crowbar circuit". You put a fat Diac across the PSU output and a zenner diode to trigger it should the volts rise above your max threshold.
When you trigger a Diac it stays triggered, hard on, until the Volts go away. A cheap Diac can handle lots of Amps.
In this case the Volts go away because the fuse blows. You then replace a 10p fuse rather than expensive hardware.
It's called a crowbar because the effect is like dropping a crowbar across the power input terminals
NEW MEMBER: Re my question
By oldwoodworker in forum New Member IntroductionsReplies: 32Last Post: 20-09-2013, 09:07 PM -
To usb,or not to usb,that is the question.
By Jumbo in forum General DiscussionReplies: 11Last Post: 17-10-2011, 09:21 PM -
Just a small question
By Wobblybootie in forum Linear & Rotary MotionReplies: 4Last Post: 06-08-2010, 05:28 PM -
question ...
By Wobblybootie in forum General DiscussionReplies: 6Last Post: 04-01-2010, 12:04 AM -
A question
By bodgeitandscarper in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 02-12-2009, 08:30 AM
